Originally posted by brodonh
Thanks for your wishes!! yes i have recovered form from quite a long viral sickness!! I have mailed you regarding the Capacitors..looks like you just have to use a combination of a series and Parallel Capacitors of the value of what you already have, also you may have to add more Mass (Coils turns) for the Batteries Voltage you are using (108V) to cope up the Impedance problem..that will drian the batteries alot slower than it is doing now..
Best Regards,
for your efforts and an impressive set up of the Motor video in the drop box. I salute your wisdom and yes you NEED NOT have to be a trained Engineer to tinker with these things.. Engineering is built-in to a natural tinkerer... rest is all Synchronicity!!![Click image for larger version
