So, I started with the two coil instead of starting with the 8 coil. I have a few basic questions.
1. What type of battery can I charge? I currently discharged a battery to 11.6V, is that enough to be charged by the bedini system? or does it have to be a battery that is below 5V
2. The power battery I used is 12 V 5Ah, is that enough?
3. For the core, instead of 1/16", I used 1/8" lincoln r60 rods. Is that okay? Can welding rods be used if they have flux on them?
4. The wheel, I used a wheel that can attract magnets, will that interrupt the system?
5. The wheel I used is 20 inch bicycle wheel with 12 magnets, will that be enough? if not how many should I have?
Hope to get some feedback from y'all so that I can build it from the basics and learn more from the motor.
Thank You so much for your time in replying !
