Harlan Sanders,
The machine deals with Tom Bearden's Four Wave Mixing. The machine deals with a low frequency pump wave through a modulation transformer. The machine uses all Ne555 timers set to select frequencies Values for the first timer are as follows, The current through the electrodes must not exceed 50 Micro Amperes.
150 Ohms between pin 8 and 7
220K variable pot set for low freq square wave 50Cps between pin 7 and 6 pin 2 and 6 tied together The cap value .22Uf pin 1 to ground.
Other values are in the same arrangement.
IC Two. 150Cps
50 Ohms
50 K Variable
.022 Uf
IC Three 350 Cps
50 Ohms
50K Variable
0022 Uf
IC 4
680Ohms
100K
.047Uf
IC 5
680 Ohms
10K
.01 Uf
IC 6 Set to highest frequency.
680Ohms
250K Variable
.0039Uf
Pump Wave IC NE555 set between .8 to 8 Cps
Values 150 Ohms
1Meg Variable
2Uf
John
My Work on Rife
IC Two. 150Cps
50 Ohms
50 K Variable
.022 Uf
IC Three 350 Cps
50 Ohms
50K Variable
0022 Uf
IC 4
680Ohms
100K
.047Uf
IC 5
680 Ohms
10K
.01 Uf
680Ohms
250K Variable
.0039Uf
Values 150 Ohms
1Meg Variable
2Uf
John
My Work on Rife
