Each S+H S+H S+H S/H each unit.
Part code Price CAN USA INT Description Stock available
PCB-AIR1408560 $16 6 7 9 140 LED, 850nm, 60 deg. >10 available
PCB-AIR1408530 $16 6 7 9 140 LED, 850nm, 30 deg. eBay LIST STANDARD UNIT
3 4 5 SH per additional board
PCB-AIR2248520 $19 7 8.5 12 224 LED, 850nm, 20 deg. 10 available
3 5 7 SH per additional board
PCB-AIR2528510 $24 7 8.5 12 252 LED, 850nm, 10 deg. 4 available
PCB-AIR3508530 $39 8 9.5 15 350 LED, 850nm, 30 deg. >10 available
PCB-AIR3508510 $43 8 9.5 15 350 LED, 850nm, 10 deg. 7 available
4 6 8 SH per additional board
PCB-AIR5608520-R $35 9 12.5 20 560 LED, 850nm, 20 deg. Repaired, used, good 1 available
5 7 20 small packet
PCB-AIR1408530 (140 LED, 850nm, 30 deg.) is the standard shipped item as priced on the listing. Other LED panels are priced as listed above. Check out 1 unit and please specify the LED array and quantity you want. I will send you an updated invoice with shipping. Also available are LED power supplies and heatsink parts and hardware. Quantity discount available for multiple units. Please contact us.
That's the one - red I got it now - http://www.ebay.ca/itm/130749511336?...84.m1497.l2649
What I was thinking is to replace a field, say 6x8 LED in the center with IR's from other panel. If I could afford I would buy all these IR panels. He also has heatsinks, power supplies etc.
Vtech
, just teasing. I've been testing my LED pulser and rehomed to pcb last night. Everything works fine. I ordered 15V4A Toshiba laptop power supply which has the same jack as my LED panel (6.3mmx3mm) and found small rotary 7 position switch which is in the mail. Everything should fit nicely inside the panel when done. -
Photos below are IR 140 LED panel and my pulser idea.
If I could use 4017 decade counter with 4093 NAND gates......I could (perhaps) run the clock input from another slow astable multivibrator. Each pulse will cause to switch between seven outputs of 4017. There is also an option to leave it on one of them on by using EN/RESET inputs.
