Tried reversing the diode from HV to coil +, and I get sparks but at slightly reduced output; at least the spark will not jump as large of a gap as it will without the diode. Tried several different identical diodes - brand new - same results.
Now thinking that click/buzz that happens with the diode is actually coming from the wires going to coil + and -, not inside the CDI. No clue why that would be though, they seem in good shape.
I'll run by the electronics store and pick up a couple different diodes and see if that helps. Any particular one you know works well? Will try a different coil after that, but am a bit low on funds. Does it make a difference if it's a box or canister?
I would very very interested to know what kind of results you get.
