Hi Julian,
The battery size needs to be favorably matched to the size of the SSG. This means small batteries for a small machine with a single power winding on the main coil. I have a small SSG I started as a replication of Shawnee Baughman's little machine shown in the beginners handbook. I had trouble getting it to not blow the transistor, so changed a few things and got it working very well with a MJE3055 transistor, 2.75" diameter rotor, 1.5 x 1.75 coil, and 5.5 AH 12 volt batteries. It will easily push the charge battery over 15 volts in probably less than an hour. Here's a link to a video of it running on the battery swapper I made so you can see the relative size of the SSG in comparison to the batteries. https://www.youtube.com/watch?v=DE-CvurRW5U
Gary Hammond,
Originally posted by JulesP
Gary Hammond,
As you will recall, Rodolphe, who has replicated my V4 setup using a PWM, regularly gets around 15V with a 12Ah battery. So far we haven't made sense of this situation.
