@ Guy,
Really man, that's it? That disappoints me a little...
I will say again, I post this stuff for the benefit of the group. I do not need to come on a public stage to teach myself what I already know.
I will let you know if my drum kit starts floating away ;-)
Seriously that was some interesting stuff. I'm not sure I followed the whole of what he was saying but it did spark some idea's. I do not go to other forums, maybe on a rare occasion but I find it hard enough too keep up with this one. I'm sure others are using Arduino too, it just makes sense to use such a perfect timing device but I have not seen anyone using it in the way that I am on the trigger with no wire. That doesn't mean they aren't of course but I came up with this independent of others.
@All
The thing is when you loose the wire on a SS it takes a lot less to drive the base, I mean a lot less. Probably because of the mutual induction you get between the power and trigger coils and it just takes more energy to fill that trigger coil than it does to tickle a mosfet. They are not current devices after all and that is huge. I mentioned it before but I first tried with some crystal cells and they did actually work but just not strong enough, I was getting a weak spike. The point though is that even such a low energy cell like those (talking the copper/mag) is enough to trigger the power coils. I still may get them working on the machine but I probably need a few more. The actual switching across the power coils is super clean at all speeds with this setup.
The trigger coil on a SS is sort of a left-over from a former life on the machine (I am coming to realize). It serves it's purpose very well on a mechanical setup, brilliant! When we move the wire however and take from the primary instead of magnet induction it changes a lot more than you might think. It does run and some of them run very well but the main thing is the SS runs at such a high frequency that things occur which do not and can not on the slower mechanical setup. The induction of the coil is no longer free from the magnet, it is paid for from the primary and we do not need an inductor to open the base at that point anyway because we have lost the mechanical advantage. What we are doing when we do that is taking 12v and reducing it down with massive resistance and 100+ feet of wire to go to the base. It had a purpose when the energy was free but in a SS it is not.
Heck you don't need an arduino to put it to the test. You could do the same thing with a mosfet, a source, and a tiny dc motor with a magnet on a flywheel that triggers a hall sensor or something. Arduino kicks ass because you can program every detail of how you want to fire but what I am saying is we do not need to use 100+ feet of hookup on the base in SS. Know what I mean yet? I said it before but I also want to say again that it is a huge benefit to have a steady voltage of the same pressure tapping the base. Far better than wildly swinging voltages.
Anyway that is all mumbo-jumbo that you can take or leave. I can tell you though that this thing now runs like a dream! Best freaking charging I have seen in a long time AND very efficient. I am not just some guy who just showed up and started changing everything in site with no understanding of how things work. I have built many devices over the years, mechanical and SS. Some didn't work out and others worked pretty good but I do have experience from it all.
Nice work! I'm going to have to put that arduino on my todo...
There’s a lot of good info on Arduino controlled SS SSG on the energetic forum and youtube. Much discussion on optimizing duty cycle relax coil time etc…
One of my favorite Arduino controlled SS SSG, people can say what they want about the UFOguy, but one of my favorite Arduino controlled demo’s is this series here:
Much has to be taken into consideration when we take the control away from the coil, now you have the control so it’s up to you, front end, back end, coil etc... The hunt is on to find where the radiant is :-)
Kind Regards,
Patrick A.
Kind Regards,
Patrick A.
@All
and then the weathwer gets good enough to start riding dirt bikes again....
In fact, I appreciate most of what is shared on this forum and try to keep up with all the new posts every day.
