I recently replaced a 20" 17 magnet wheel with a 26" 21 magnet wheel on 7 transistor SSG using the same magnets (from Teslagenx). The SSG won't change up to single spike per mag unless I push the coil away and let the RPM build up, once past the threshold it will be fine and I can bring the coil closer again to where it seems to run the best at about 9.5mm (3/8). It's not a major issue as the coil sits on an adjustable platform, but eventually it will bug me.
The 20" wheel would change up fine. Why would this occur with the 26"? Does my SSG base resistance need to be a little higher? Rheostat's are expensive!
And wow, I'm amazed how much the tiniest change to the coil gap affects the machine. I have nylon screws to adjust the coil platform and quarter or half a turn (half a millimeter or so) is enough to see a difference in charge on my CBAIV.
Edit: I have one spacing between magnets that is about 5mm different than the rest, could this affect it that much, it does kind of do a "chug, chug, chug" thing until I make it switch up.
