Originally posted by John_Bedini
I was following your research over last two years and it is always good to see your efforts on free energy research field.
My first radiant spike circuit was your SSG..
Over that time there was long road forward and I did lots of things including energy from NMR - Ferrite magnetic polarization (work in progress) - YouTube Your circuits are always on crossing ways with all other and the missing puzzle for holy grail part seems is second signal in all free energy devices.
Here is my comment on your The Workings Of The SG Oscillator - YouTube - the radiant voltage spike is one of two components for full circuit and the second input signal should be reactive current taken from LC circuit in series(in 180 degrees to phase of voltage spike)... When you mix those two and put to charge battery after rectifying those mixed signals you may be very suprised...
The principal circuit I have in mind is there: Simple to build isolation transformer that consumes less power than it gives out
Hopefully it will ring some bells
With your persistance and knowledge on this topic that part can be easily tested on real experiment.Cheers!
