It seems pretty consistent on my system. Who knows though, far to often we try to attribute one thing to another when really there is something else going on.
Try it out and see for your self, I would be curious if you get similar results. All you need to do is slide your primary coil to one side a bit. When you spin one direction it will be advancing , the other it will have a retard. Pretty simple thing to play with. You will need a pot on your trigger however to adjust the current because the retard state draws less if given the same resistance so just as I did in the video you would need to adjust it to the same draw rate as the advanced setting. Also without adjusting the resistance at all I notice it still charges a bit better in the retard configuration but I was trying to make it apples to apples.
It would be easy to test on an old 3pm kit too if you had a pot hooked into one. Mine has been heavily modified and uses a different circuit so I can't use it to verify. The thing is that multi coils may have a lot to do with the effect. The primary coils power winds will be positioned the same as the trigger but all the slaves (28 on my machine) will have the offset. Not sure if a single coil machine will act the same.
*EDIT*
Another forum member PM'd me and pointed out a mistake I made in the video so I want to clarify. In the video I described the coil being moved to the left and the others to the right which would result in the reverse of what I described in regard to advance and retard. My mistake was that when adjusting the coils I am working on the machine with it spun around, looking at the back so I mistakenly said it backwards. When looking at the machine running the primary coil is shifted to the RIGHT and the slaves a little to the LEFT. Sorry for any confusion.
*EDIT*
