Hi Yaro,
Your ZFM motor is looking good. Will be anxious to see it running and view the test results.
and it would auto rotate when powered up. The initial results were truly underwhelming due in part to an excess of bearing friction and other minor issues. The bearings were removed, the seals trashed and the grease cleaned out of the races. After reinstalling the bearings a light turbine oil was squirted into the bearings for lubrication. The alignment in the ZFM assembly was carefully completed and the net result was worth the effort.
